Team Helix (how to identify angles)
F
Flying Dutchman
Polaris Klim
2003 RMK700, the secondary is a Team. I've always run button clutches, so know nothing about these.
It is a TSS98..The Helix says Rapid Reaction, Twin Trax.
How do I find out the angles???
The numbers on the outside have been etched out and "mountain" has been stamped instead.
On the inside by the ramps, there are no numbers of any kind.
And, if it's a twin trax, would that mean there are two setups in each helix? (either of which I do not know).
So, is it possible to figure out, measure degrees???
Or if it runs fine, do I just forget about it?
unfortunately for you, it sounds like you have a helix that someone was trying to keep secret what angles they were using from the early days of the team. this use to happen more often b/c a specific shop or person would go out, do a bunch of testing, figure out a combo that worked well and then sell that to the public. so understandably so they didn't want their hard found "secrets" known to all. this way they could sell more kits. the bummer part for you is you have no idea and no way to figure out what your angles are. sorry i'm not more help. maybe someone else will be able to offer up a better suggestion. good luck to you.
pv
you could send it to team and have them run it on there angle ploter but it would
cost plenty , if its working good forget it..
