Tcl delete m1100
Is anyone doing any tcl deletes using new parts from a 2014 7000 just wondering what it takes to do it I would think it wouldn't be to hard the parts cost is under $200 but not to sure what will work or not work
The YamaCat bracket will not fit as it is contoured for the Viper/7000 and also needs pickup points to mount that the 1100 turbo does not have. Our TCL delete kit is available in stages depending upon budget. The TCL delete bracket is available by itself for $479. A stage 1 kit which is the TCL Delete bracket and straight bearing and motor mount kit is $579. Most guys with 1100's should do the stage 2 kit at a minimum because of the heat exchanger cracking issue. The stage 2 kit includes the engine brackets which remove the factory heat exchanger tabs. The stage 3 kit is $1299 and includes our "unbreakable" jackshaft which is about 4 times stronger than stock.
