Tank of oil a day
Montgom345
I just installed a rkt drop in kit for my 2012 pro. I'm out in Cooke city currently and the last two days I've gone through an entire tank of oil each day. Roughly 80 miles a day. Any suggestions would be awesome..
Did the linkage that connects the throttle bodies to the oil pump come undone?
The pump arm can also flip around and stick in the full open position. Verify that if the rod is connected, the arm is facing downward, not up.
Any chance you could have developed a leak in the oil line after reassembly of the top end?
I believe I wrote in the first write up. But If not, no I have never touched the oil settings. I've talked to a couple of guys n thinking possibly my oil pump is stuck wide open.
You have something screwy. Mine is turned up 3 turns and I get just over 2 tanks per tank of oil
