D
Danbot
I have noticed over the last couple years, that most nicely modded 900's seem to sit very high up, the front suspension looks jacked as if there is almost no sag whatsoever.
After light discussion with a few friends in here it sounds like sometimes this can be credited to the design of aftermarket a-arms and / or shocks.
I think that this:
1- looks good
2- offers more ground clearance
So, I am considering trying a setup like this to see what it feels like like on my 900. My first concern is that I will have to compensate in the skid for the taller front end.
As it sits now, if I add ski pressure with the ski shock preload, the heavy steering and diving I fought to get rid of returns.
In my minds eye the solution would be to let out the limiter straps and add some preload to the front track shock. This should maintain my ski pressure balance while jacking up the front right?
Secondly, a question for those of you who have run a tall ride height: What kind of handling characteristics come out of this?
I would guess that it's going to feel more top heavy, and since the COG has been raised, it will be less forgiving over rough terrain.
Here`s my setup, in case it becomes relevant in this discussion:
06 Switchback
Stock Switchback stance a-arms and spindles on top of Grippers
Fox Zero Pro`s all around
Stock ski springs (set about half way down the threads)
225lb front track spring (set about half way down the threads)
.375 torsion springs (softest setting on the block)
Limiter straps in the middle hole
Any insight is appreciated, what are your thoughts guys
Dan
I think that this:
1- looks good
06 Switchback
Dan
