With all the talk about the P22 being garbage and guys using the P85 instead, where are all the P22 take-offs for sale? So far I've only seen one here on Snowest, and none elsewhere. Are they literally just going in the garbage?
Going on the shelf, just in case it's needed.
Look at Muskoka's buddy. He put a p85 on and keeps showing up with the p22 to get other guys sleds out. He probably has 50 miles on the clutch on 4 sleds.
i already have a full ibexx turbo set up on my 19 so would be a straight swap thenP-22 and p-85 weights don’t interchange. Get the TRS p-85 set up, it rips
gotcha, they matryx na clutches then. good info thank you.Check the crank size. I thought they didn't change the 850 until 22?
22mm vs 23mm iirc.
don't think that is correct. '21-up 850 lists the same crankshaft and primary clutch. the '20 crank shows not available, but the the primary is the same ??Check the crank size. I thought they didn't change the 850 until 22?
22mm vs 23mm iirc.
