My coolant hose blew off of the head while up in the mountains, and I can't get it to circulate. This machine (1150 cutler) has always been a pain to burp, but it seems to be building up pressure in the bottle.
I've raised the front of the machine as normal, but nothing. It does not circulate to the rear coolers, once I let it cool down, I try taking off the coolant cap and LOTS of air blows out..this has never happened before when trying to circulate, then, it starts to overflow and then the bottle is empty.
At one point, when I took the coolant cap off it blew all over the place, it was room temperature. At times, the coolant will start to run out of the pressure relief spout on the coolant bottle.
When I try to take the thermostat cap off the head, lots of air blow out.
The system seems to stay pressurized even after several hours, as when you let the cap off of the coolant bottle you can hear the air come out.
Possible base gasket? Or is it the head??? Could it be either one?
Any help would be great.
Thanks.
Thanks.
