I am a lighter guy and have trouble throwing my 10 800 rmk on its side. Would removing the sway bar help in the mountains and how hard is it to remove? Anything else I can do to help?
What kind of shocks do you switch to and how much do they usually cost.
It is a RMK, not a dragon. It has walker Evans without any coil overs on the front. How do you know if they need to be rebuilt? Can I rebuild them and have them charged, or just have someone else rebuild them. What does that company charge to rebuild.
I just changed the limiter straps to the lower hole. Hope that helps. Any other tricks to try?
Thanks for the help everyone.
I only did the piston upgrade and shims and it made a big difference, plus you can have them set the pressure higher specifically for running without a swaybar. Worked for me. Once the piston upgrade and shims are done, you just need to recharge once a season unless you put on a lot of miles in which case you should have the oil and possibly seals done too.This is what Fabcraft charges for the Walker Evans air:
Shock ComponentRetail Price Spring Rate Chamber$95.00 ea Piston Upgrade Kit$40.00 ea Shims (usually 4 per shock)$2.50 ea Labor (includes oil, nitrogen)$40.00 ea
The $95 charge is if you want the extra chamber added but it isn't necessary.
Yeah, I hear you. LOL Just a matter of practice to find and maintain that balance point.I was working on counter steer, but seems like I loose it half way through while trying to do a 180 and head the other way. Have my most trouble in tight spots trying to do quick maneuvers and avoid the bottom ground where you don't wanna end up haha
Don't look at he land mines or the trees.. u will go right for them
