We always drilled out bottom hole for the front mounting hole on the track suspension, dropped the rear mount to bottom hole in bracket and added an additional hole to let limiter strap out slightly more than could be done with the stock holes. Before the days of paddle tracks we also installed the Simmons speed cleats on the track but they had to be replaced each year due to breakage. Cycle Works out of Alberta made a set of cleats that had a lifetime warranty and I started running those instead. You'll want to keep your ski pressure light for the powder so don't preload your rear springs too much.
