C
conter4x4
New member
Ok, I've got an 07 summit x. This last off season I switched over to a 154 08 rear skid and track. I dropped the front suspension mount 1 inch and moved it back 1 inch. The rear has the tricked toys drop bracket which is the old smitty's drop bracket. The rear is mounted in the bottom front hole on the bracket.
Now the issue Im having is the front end feels heavy. It plows on the hill and on the trail. I've tried messing with the suspension. I've gone from number 2 to number 5 on the front shock adjustment. Not much change. I've had the rear springs set on 2,3, and 4. The center shock set from just having the springs tight to now having it about 1 3/4 inches 9f thread. The best rules I got for steering is 2 on the front shocks the center shock with the 1 3/4 of threads and rear springs set on 3. It still plows but not as bad. It still doesn't want to turn on the hill. If anyone has had similar issues and found a fix I'd love some help.
Thanks
Thanks
