Well, just a note on the Tied... and it ain't your problem as I've got the same on my sled (same helix as you) and have had it out 6 times this year and it is very responsive so I wouldn't focus on it.....gotta be something else.
You need to PM Winterbrew and ask him what happens to Skidoo clutching when you gear too low.....
Also, the only variable which you have changed that would really have this much affect on your wheelie factor is the head you put in.......
Here is what happens when you change a gear ratio to a lower ratio
or
When you change the overall ratio (aka smaller drive sprocket diameter)
The term(s) tuners use "gearing too low" or "geared lower" is a "label", a descriptive marker that is attached to a result of reducing "overall drive ratio"
Gearing commentary
IF you can remember the theory "The law" of how the parts work, then you change your overall drive ratio and see "X" result...
THEN you can apply other theory "the law" of how the parts work to compensate for the lower gearing.
An example.
You can run a gear set with 21:49 as stock with a 413 ramp and reveal "rated rpms" (8150) right to full shift.
If you were to run a 20 or 19:49 then make the same run down a road to full speed, there is a great chance that you'll observe rpms that will stay at 8150 until the load changes (bumps, cycling throttle for a corner, snow getting slight deeper) then the rpms will reduce. [remember the lever is doing more work being farther out on the ramp]
Alright...
You reveal lower rpms under re-applying full throttle.
Ramp example illustration ( i will get a picture of 413 vs 410 vs 417 and post)
You can take the 413 ramp out and install a 410 or a 417 as each of these ramps have an increased angle towards full shift compared to the 413.
Law - If ramp angle increase; Then rpms increase. Then rpms quicken from one rpm to a higher rpm / time.
Example question arises -
what spring force is being used at an example 45mph track speed? (look at track speed at bottom of chart)
You can look at your primary spring final force. The rpms reduced with a xxx/260.
You can remove the xxx/260 and install a xxx/290 or a xxx/320.
Each time you raise the final force then you will be adding more spring force at-the-moment-during-upshift where the rpms start to diminish or become sluggish.
How much spring force you add at-that-point-on-the-upshift will determine 1)how much the rpms will drift low. 2)how quick the rpms will recover.
there is always an easy way to get around drifting rpms due to a gear change.
