I'm not sure if you are missing this or I'm just not following you.
Melting does in fact take extra energy. Any time there is a change of state either ice to water or water to steam you have latent heat. It takes 1 btu to raise the temperature of 1lb of water 1 degree, but it takes 144 btu's to change state of 1lb ice to water or vice versa. Steam is even higher at 970 btu's.
Bottle in the bibs vs internally I can't speak to although I wonder if it has to do with the fact your body is always giving off waste heat but if you ingest the water it is now using energy specifically to warm up the ice/snow. Of course warming it up on a fire would be best but eating frozen water definitely burns considerably more calories than even 33 degree water.
Ok, so I am interested in this.
144 x the energy to change state just seems AWFULLY high value -considering how frequently the puddles in my drive change state, and now little my drink cools down.
Maybe you are just fishing to see if I'd bite?
My quick research shows that it takes 334 joules per gram to raise the temp of water one degree.
While I found that the energy required to change state is 419 J/G.
So that is 25% more energy for that slight point of transformation from solid to liquid, not 14,400%.
I have never studied this before, so if I am getting bad formulas from the web, or my
math is buggered in any way, please correct me. I seriously would be interested.
My info sources:
https://www.engineeringtoolbox.com/heat-work-energy-d_292.html
https://www.thoughtco.com/heat-of-fusion-melting-ice-problem-609498
Of course, if you, or someone in your group is chilled, and you are able to warm it up to coffee type temps, that would Shirley help to warm them up. I was only commenting on the solid/liquid thing as anytime that I have seen that brought up - I always git the impression that they feel like 33* water is so much better for you than snow, and I am only challenging that aspect.
edit:
I thought that Joules was a much bigger measurement of energy.
Don't they rate lightening in joules?
I'm a little more at home with KVA.
