supertip washer?
O
obile
Polaris Klim 509 Starting Line Products
just purchased a set of supertip weights. the instructions say to use o ring for 1 or 2 of the 1 gram washers. did this in the mid using 3 in the heel and with the screw all the way tight there is just a little play in the washers. not enough room to put the o ring with 3 washers but still loose. should i be concerned about this or run it like that? thanks for any help..
I always run a o-ring with 3 washers. It will fit, trust me. Three or less, put a o ring in there.
I'll second that. I can't find any litterature on the STM site, but three or less washers requires an o-ring.
you can get that fat little o ring in there? or are you using a narrower one. guess ill give it a shot. tighten it all the way down?
Yes, that fat little o ring will fit, you need to press it on but it will go. Then tighten the screw all the way down, washers, o ring and all.
