Supercharged Phazer misses
MPI kit on my Phazer- smack it from dead stop- misses, stumbles. Ease into it then all is good. Just curious if anyone has some answers? Thanks.
Here is the instruction on your GEMS:
http://www.mountainperformance.com/Files/Download/hse-0348 Phazer SC GEMS Controller setup.pdf
I found this in the nytro gems info:
(5 e)
Programming Mode 5: Yellow/Blue – Accelerator Pump. – Factory Set (v1.0=1, v1.1 & v3.1=4)
Adding to this number will increase the shot of fuel that is provided while the throttle trigger is
moving. The Pump is speed sensitive, that is the faster you move the throttle the larger amount of
fuel is provided. Try adjusting in steps of 1 to 2 numbers at a time. NOTE: The accelerator pump
does not function if you open the throttle as fast as humanly possible. Try slowing down the throttle
opening rate just a little bit; you will enjoy much smoother results.
If you take a look at the bold part from the gems instruction i pasted you might get a clue why it stumbles.
