Well I finally got around to checking the ignition components with my fluke meter. I verified the kill switch and dess switch are both good. The ignition generator coil also tested out fine. I then went to check the trigger coil and the spec is 190- 300 ohms. But instead I have 2.621 M ohms or roughly 2,621,000 ohms. So I would assume that this means the trigger coil is faulty, correct? I also checked the primary winding resistance in the high voltage coil and that was also in spec. I did remove the air box to make testing these parts easier and noticed that one spark plug wire was getting some wear on it from rubbing on a hose clamp. It wore through the hard plastic cover and it looks like it just starting wearing into the plug wire, but since it tested good and since it was only on one wire should I replace the trigger coil since it is out of spec?
