Summer storage tips for 4-stroke?
Got the track up, lubed it up, and cleaned it. Do I need to add fuel stabilizer? And what about the battery (electric start) should I trickle charge it? Also, any use in taking the belt off? Thanks in advance!! Any other advice would be appreciated...
Good idea to add fuel stabilizer or just add "Sea foam" works well. Not a bad idea to put a trickle charger on the battery either. Change oil (chain case and crank case) before you put it away. That is really about it.
