If I can spin my primary clutch with no resistance at all does that mean that my crank end broke or is it something else? The engine is 03 800 escape.
Thanks for your help.
Stator,crank, or hole in the piston. One of those bud.
hmmm good question... does it spin when you pull it over? take the bolt out does it fall off? im guessing either your clutch is screwed or your crank is severly messed up
did you check if there was play in the crank by trying to pull the clutch up and down and back and forth
my brother took his crank out last year and it would still run and the only way we figured it was the crank was the very little play there was by pulling the clutch up and down and left and right... if there is no play there then i think something broke loose and the end of the crank or in your clutch
im no expert by anymeans but thats what i would look for
yep sounds like a broken crank,,,,if you are looking fix it ,get a hold of me I have what you need,I am parting out the same sled,tried to sell it whole but could not get enough,and I have a -0- mile motor with 3 year bottom end waranty.i think I have the top half sold,so I could make you a good deal on the bottom end.xsx
Same thing happened to me. Put 4000 miles on the stock crank, sent it to SLP, and bought a new crank from them and had their bearing installed on it. It broke after only 700 miles. They will not warranty it, I called and they said send it to them and they will try to fix it for 5 or 600 dollars. I sent it to Indydan and had it fixed right with a 3 year warranty. I think SLP has really nice stuff and the guys in the machine shop do great work, but I think their Tough Boy Bearing is a POS. Just my .02. Here are the pictures. The crank broke in the center of where the SLP bearing was installed.
BTW If it's broke like mine. you can not use a puller to get the clutch off. Indydan welded the crank back together and then pulled it off.
