I got an '05 M7 acting funny as far as the check engine light goes. I can be running down the trail and it will start to flicker, almost like it is trying to constantly flash. IIRC a constant check engine flash means the sled is getting hot. So I stop and pack snow onto the top of the tunnel and throw a bunch of snow on the engine, etc, etc. Let the sled cool off good. Start back up and go and have the same problem. The sled runs great, doesn't act like its too hot, but the light tries to flash still.
When I say tries to flash I mean it will flash a couple of times then dim out, then kinda flicker back on and back out intermittently. Sometimes if I stop and idle it will stay on constantly but the sled won't be hot, and when I start going again it will dim out and every once in a while try to flash.
My guess is maybe I have a short somewhere or that my coolant sensor is shot. I can't find a short so that leaves me at the coolant sensor. Do these go bad? Where are they exactly? Is there a way to test them? Any other ideas? Thanks.
Cliffnotes: I think my coolant sensor is shot, does this happen?
