Sticker Residue!
3 M also makes a adhesive removal wheel, you mount it on the end of a drill & just "graze the surface" It pulls the sticky stuff right off, use it on trail stickers, wraps, de-badging autos/trucks. Works like a charm no harsh solvents to attack, the paint, your hands, your brains. Well some like the "solvent BUZZ" get it at Napa
CRC Kable Kleen. Doesnt even require elbow grease. The adheasive just puffs up a little and rolls right off with a paper towell.
The only reason why I discovered this is because when I was running an oil distributor truck for asphalt, we used wd40 to clean off the oil (tar)
I was getting pissed off at the residue while removing my stickers in my garage and was out of wd so I grabbed this stuff and it blew my mind at how affective it was.
Wd may also work well, I dont know
When I took the graphics off my assault I used a heat gun to minimize glue residue left behind. In the past Ive found break clean then a scotch bright pad to work good to remove the glue the glue gets stuck in the 3m pad works alot better then a rag and break clean
