For all you guys that take off the stock stickers what do you use to get all the sticky stuff that stays on the panel? Thanks in advance!
40 grit sand paper! just gotta be real careful!
holy crap... 40 grit?? must have to be REALLY careful.
goo gone for me. let it soak for 5-10 min and then apply elbow grease.
X2 on the adhesive remover by 3M, I use it on plastic or the tunnel before I polish them.
X3 on the 3M adhesive remover, it plain works!
The other thing that helps right off the bat is when your taking the decals off, use a heat gun. Just be careful and apply the right amount of heat, to little and decals leave residue behind. To much heat and you can cause damage. Basically play with the heat gun and do a test pull on a decal and see what comes up, with a little patience, you dial in the right amount of heat and presto, the residue left behind is minimal.
Here's the 3M stuff,
http://3mcollision.com/products/cleaners/adhesive/3m-general-purpose-adhesive-cleaner-08984.html
Also the better deal is the regular can, stay away from the aerosol.
With a heat gun and the 3M stuff I went from this,
To this in no time!
To this in no time!
To this in no time!
