i'm sure theres a thread on here somewhere...but whats the best method to remove old decals...or old registration stickers? anyone have any luck with anything? mine are all on metal/aluminum... any thoughts/ideas would be appreciated!
I just removed the decals off my hood and the back of my painted tunnel. I used a heat gun to heat it up, then peeled it off. Any adhesive remaining can be gotten off with WD-40.
Will the wd-40 or acetone discolor the panels on an xp?
If it's just steel...no...if you are talking a painted steel...WD-40 won't hurt it...
3M makes a rubber wheel made for specifically removing decals. It is about 4 inchs in Dia and mounts in a drill of a Die grinder. Most good auto body stores sell them. They are a bit spendy and you will want to keep moving it around, But i have used it on painted hoods and it works well. The time saved is worth it. And the ease of use.
