Stage 1 upgrade kit for MPI Yamaha 180 kit
MPI Upgrade kit
How much more horsepower could I expect to see with this upgrade Matt ?
This kit converts your Yamaha 180 kit into a true Stage 1 kit. Includes everything you need to make the upgrade. By upgrading your 180 to a stage 1 you can run more boost over the base kit. This kit is an easy bolt on to the stock 180 kit.
TURBO
MTN-1100 $1095.00 Pre-season sale $945.00 $150 off
The Turbo upgrade includes:
New high flow intercooler
Dual sided waste gate
Stiffer Blow off valve spring
New aluminum charge tube
All the necessary hoses and hardware
Re-flash of your stock GEMS controller
SUPERCHARGER
MSN-1100 $1195.00 Pre-season sale $1045.00 $150 off
The Supercharger upgrade includes:
New pulleys for high boost
Cold air kit
This will allow you to get the max out of your supercharger or turbo kit. Both of them can make around 12psi. So that would put you in the 230-240hp range.<O:p</O:p
This will allow you to get the max out of your supercharger or turbo kit. Both of them can make around 12psi. So that would put you in the 230-240hp range.<o:p</o
Going from 180 up to 230 should be a pretty nice step up!~:face-icon-small-hap:face-icon-small-hap
Will be dialing my Supercharger up this season as well!!
Matt,
Is it still without a head shim at 12psi? Race gas or pump gas?
Thanks
Mick
