Same with mine even mag side xcept my pto side was a little whiter on top of the piston. Is this a lean condition?
Couldn't ask for a better place to make camp.
No fixing the Dragon this time, busted out the bottom of the case. Parting it out, let me know if you want some gently used parts.![]()
That kind of looks like a ford ranger pulling a semi trailerNice Digs
The outer edges of the mag piston is missing metal, like it detonated and the lower rod bearing is gone. The rear track shock is sacked out also. Anybody want to buy a roller?
I'd say that's from the lower rod bearing debris getting sucked up and chewed on. Seen it many times. lol
Lucky for me I have a spare bottom end with a 100mi. on it, and my cyl's are good,it's in an 05 summit 151 with around 2200mi. on the chassie. Mine is a X was a 144 used rail ext. and tunnel wasn't lengthened. It needs the spare nun I have installed, shocks rebuilt brake rotor rattles like a mofo, bumper's broke, front nose is bolted/rivited back together, so I will prob. use the 05 and sell what I don't need.If you were lean this time of year, I'd be tearing that entire motor down. Sounds like you may have a crank seal leaking. Go ahead and get new seals, crank bearings, pistons, re-nik the cylinders and check the crank run-out. As many miles as you have it's a good idea. Thats a good sled, no reason to scrap it.
I found some chunks of metal in my Y pipe and the rod is a little tight on the crank, no cyl. damage.I'd say that's from the lower rod bearing debris getting sucked up and chewed on. Seen it many times. lol
