Spindle bushing question.
copteazer
Should I look into these brass bushing over the factory bushing. Bent the bolt and shaft and the bushing looks shot. Seen these from Bushing werk and I can’t seem to find a write up on them or just get stock parts.
Stock ones are plastic except back in 2011-12 I believe... not impressed with plastic in a place like that... these look good to me.
If you do end up replacing them, here is a tip: Use a threaded tap to remove the old ones. They were a real bitch. Thread the tap into the brass on one side and use a punch from the other side to remove.
