Speedwerx 1000 Cat motor
jarhed
I am treading the waters here... I acquired an 01/02 Cat 800 carb based Speedwerx 1000 recently and am going to try to get rid of it. Its burnt down on the mag side and the pto side has some VERY light scuffing, could easily be honed out (I think) no damage to the domes at all...the bottom end will definitely need to be split, cleaned and re-sealed, I may try to do that yet...
Currently it has everything with it, (except drive clutch), bored carbs, ALL wiring, PSI twin pipes, motor mounts, cdi, power valve delete kit, Speedwerx billet head and domes, V-Force 3 reeds, recoil....
I also have a Racepac Avenger 2 available, it was installed on it... I got the sled blown up and will not be fixing it...
PM me with questions, I can work on pictures of the parts
thanks!!!!
so it turns out the bottom end is junk! broken crank and messed up cases, I will be parting this motor out, if you want anything off of it, PM me and make reasonable offers on the stuff...
