Spectrum 3d flyweights?
Sheetmetalfab
Anybody run these?
Between the lines designs sells them
189 bucks
Adjustable ramp angle.
Work similar to tra clickers?
they’re the ALL NEW SPECTRUM 3-D™ FLYWEIGHTS!
Designed with an industry-first, our Patent Pending hinged ramp section gives you complete adjustability in the field. Changing your weights for elevation or boost changes is now a task of the past.
The exclusive hinged ramp feature allows you to adjust dynamic mass, ramp angle and with the 6 grams of removable screw weights, actual mass can be customized for your needs as well.
Simply by turning a T-handle wrench you can change the entire ramp angle, which effectively adds or subtracts peak RPM and shift force.
WHY ARE THEY BETTER THAN WHAT I HAVE NOW?
Conventional flyweights (and all aftermarket so called “adjustable weights”), not having the rapid adjustability on three dimensions as the SPECTRUM 3-D flyweights do, have to compromise performance for the sake of giving you a greater elevation operating range with the same weight. This is accomplished with a linear final ramp profile. This means that while your sled may feel fast, at times you are missing out on hidden horsepower that was removed from the equation because of lack of adjustability of the design. Not anymore…
Doesn't seem too bad of an idea, but the only problem that I can think of is when adjusting the ramps, how do you know all the weights are adjusted to the right angle. 1 weight could have a steeper ramp than the other 2. plus the more you play around with the screw and the more the loc-tite comes off I can see diasaster waiting to happen.
Talked to them
Talked to the rep at between the lines designs. And the ramp adjustment is locked with a setscrew. Fit polaris arctic cat or yamaha. The wieght has a knuckle style pivot point. The adjustment points have hash marks to indicate which number its set at.
Interesting concept. TRA adjustability in reverse.
Many years with TRA`s taught me the ramp profile is still the most important part of that equation though.
We were told at the show that they were shipped as 100 gram weights, but for $40 they would machine them down to a more appropriate weight per application. They suggested you could also either grind them down your self or take them to a machine shop.
I kid you not.
