Answer fronm NGK:
Hello,
Sorry, but the BPR series won't work. The indexing is the biggest difference, Don't replace the GR9A-EG with the BPR9ES/EIX, as engine damage can result.
Best Regards,
Andrew Hauenstein
Technical & Training Specialist
NGK Spark Plugs (USA), Inc
Not much of an aswer.
Just for kicks I emailed NGK tech support and asked:
Polaris calls for the GR9A-EG in my '12 Switchback 800
Will the BPR9ES or the BPR9EIX work ok?
What is the difference between the GR9A-EG (2012 model sled) and the BPR9ES (2009-11 Models) plugs?
Answer fronm NGK:
Hello,
Best Regards,
Andrew Hauenstein
Not much of an answer.
I just checked the factory plugs on my 2012 Assault and they were opposite of what you just mentioned. The open section was pointed towards the exhaust. I put some bpr9eix irredium plugs in and the gap was pointed towards the intake ports. Anyone know the correct way or if it even matters??INDEXING--most high performance 2 stroke engines require that the plugs be indexed--the open side of the electrode must face the intake port for proper flame and timing. This is an important issue. Mark the open side with a marker on the insulation and see if it lines up with the intake--if it does, you are correctly indexed. Sometimes you might have to try several plugs before you can find properly threaded plugs to give you the proper index--I think 20 degrees either side of center is OK.
BCB
really? I've never heard that low even for turbo aps.
Also.. The Gaping them at .018.....
Is what i do... You can do something else..
Easier for the Coil to Jump a Gap of .018.. then a gap of .027
It all the little things in a sled, that add up to a "Great" running Sled this is just one of those things " I Do"
Its Always works, Why change somethings that always works for me!
IDK, Maybe out of Habit!
Happy New Year!
BCB
Is it easier for current to jump the smaller gap, absolutely. But at the same time it creates less spark and would for a shorter period. Also, reducing some plug heat.
Are you going to notice a difference either way... Likely not.
I cant even remember the last time ive checked plug gap.... I glance at them, and as long as theyre not visually closed or open, i dont worry.
Sooooooo... I just bought a used 2011. It had Champ RN 57YCC in it but the owners manual supplement says to use BPR9ES. I think I'll run the NKG they were $2 each at FF. Any problems with that?
G man, I had much different results running the Champion RN57YCC's in my '06 900 RMK. I could count on at least two or three per season failing on me. The NGK BPR9ES were much more reliable. The BPR9EIX (iridium) were even better yet and these are what I'm carrying for spares in my Pro.
You sure you're not confusing with the RN57YC (which I've used in my Doos and worked great) which is the direct offset to the BPR9ES?
