Source for bearings in western WA?
I remember reading somewhere that Polaris XLT drive shaft bearings are a standard size that can be purchased at a bearing supply place for a lot less than at the Dealer. Is there anyplace in western WA (preferably north end around Lynnwood or Everett) that I can get a PTO side drive shaft bearing (not the chaincase bearing)?
I believe that pto side drive shaft bearing has a round outer race, which is not common. The chain case bearings can be purchased at NAPA. Dave
Bearing houses
If thier is a number on the bearing im sure that Kaman bearings at 253-896-2543 can help. You might try Mcguire bearing as well at 253-572-2700 i have bought many a bearing from them for my bikes and hawk. Kaman might even have a location close to you since both of these locations are in the Tacoma area.
Good Luck
There is a Kaman in Everett at the end of Hewitt by the water. Talk to Mitch, he is a good guy and will help in any way he can.
ttt..
Anyone know of any suppliers in the Eastside area?
I have tried McGuire, Kamen, US Bearing..
Dang special yami parts.
Nothing on the eastside, sometimes you get lucky at Napa but usually not on specialty bearings.
http://bearings.com/usa_products_and_services/our_locations.htm
Not sure if this is close enough for ya, but I've had good luck with these guys. Chain case bearings were 60% less than cats. If you do a google search more will come up.
G
I tried that place too. Oh well, guess I will have to make another run on monday and do some special ordering.
Thanks for the help.
FYI, for all the sounders. There are 3 or 4 MAJOR bearing suppliers located near 4th and Madison on the south side of seattle.
My 20 bearings from yamaha were 7 bucks..
Something to keep in mind..
Bearings, US Bearings and Drives Seattle 206 762-3800
Applied Industrial Tech Seattle 206 223-5255
McGuire Bearing Co. Seattle 206 767-3283
I like the people at McGuire have been dealing with them for years. But both US and Applied have come through for me in a pinch also. Also not all bearings are created equal. A lot of napa bearings are bottom end. Ask the bearing house for a top bearing and they will get you one.
If you need seals do not waste your time or money at the dealer or bearing houses. Go to Omni Packing & Seal Co.
132 South Orcas ST Seattle WA 98108 206 762-3850. I was able to get all of the seals for my Nytro chain case there at a fraction of the cost. They even had most of it in stock. If I remember right the only one they had to order was the high temp one where the brake is.
dang!! well, at least I know for the future!! :beer;
you have a pm also..
