M favorite part. the operator wasn't wearing a helmet or anything. Now thats confidence.
a case 580 loader can pick up enough stuff to get the back end off the ground, with a heavy box scraper and 4 solid steel forklift wheels... Forks and 5/8" 12' long drywall can be heavy. You can also easily get the bucket and box in a position to get all wheels off the ground. Same with a loader back hoe.. you don't even need the stiff legs, just the hoe.machine has been modified for sure, i dont know of any machine that can lift its own weight
the front of the track was hinged in the scaffolding thing.. or are you talking about something else?or balance on the front of its tracks without going over backward.
had to watch it again, didnt see the piece holding the track the first time. as far as the hydraulic power i understand that pretty well and lifting the entire weight of the machine is different than lifting one side or end because 50% of the weight is still on the ground.not saying it cant be done just think there would be some modifications to the pump and hydro. cylinders to get it done imo.a case 580 loader can pick up enough stuff to get the back end off the ground, with a heavy box scraper and 4 solid steel forklift wheels... Forks and 5/8" 12' long drywall can be heavy. You can also easily get the bucket and box in a position to get all wheels off the ground. Same with a loader back hoe.. you don't even need the stiff legs, just the hoe.
Also, trackhoes can easily pick them selves up on a side, or front to back. I think you are underestimating the power of the hydraulics on these units.
He is in a roll cage..
Whats your point? With that logic a race car driver doesn't need a helmet either.
