I ride in the spring... In California, at 7-10,000 feet in 60-75 degree heat.
Yes, in those situations, I find the stock cooling system to be lacking on the PRO even with the standard snowflap and scratchers.
I also find the stock suspension on the PRO to be an excellent performer. For hardcore riders, huckers/jumpers/mougul-pounders ... the Assault shock package is even better.
There is a small group of people out there that fit solidly outside of the norm... Some of them can be taken care with springs and a revalve... while others can really use the features of a quality aftermarket shock.
Mark Holz, who is a died in the wool Fox shop with an undisputed level of chassis setup experience over years with some of the best mountain sleds out there... He believes strongly in the Walker package and how well it works... which is why, even though the profit margin is really not there like on shock sales, he has come up with an effective re-valve program for the sled.
Just like a tailored suit... a tailored (custom valved/sprung) set of shocks just "fits" better.
GMan, since you change the shocks out on your sled and ride in spring conditions...Why did you get the Pro as compared to the std RMK with the front tunnel/bulkhead heat exchanger installed?
Please don't take this the wrong way... It is my sincere wish that your sled exceeds your desires and gives you the kind of ride characteristics that you want in your sled.
The Walker Shocks are a good shock package on the PRO, IMO... the adjustability is excellent with just the preload changes and the valving can be set up however you want it to feel. If you need more spring rate, then you can get an inexpensive spring to help with that... if you get the spring and are a light weight rider... you should probably get into a revalve so that the rebound with the increased spring force is controlled.
Gman086: There's no chance I'll be satisfied with re-valving the current shocks as I'm coming off Tom's Evol R suspension on my Summit and I ride aggro; I need a progressive shock.
You sound like a very aggressive rider to me, so it is quite possible that you are better served with a stiffer spring (you claim in other posts to repeatedly bottom your skid) even though you are a lighter rider. If you are a lightweight aggressive rider and need more spring rate... then you will need to change rebound damping (valving) to control the return rate of that stiffer spring... Just ask Tom Dines about that one.
IMO, this gives you other options than a $2500 set of shocks. The Holz custom revalve program is only $75 per shock... and that includes a full service if you 2011 guys are considering it.
In the end, if you really need to have more adjustment as well as a firmer ride with control over that "firmness"l.. then you fit into the 5% - 10% of the RMK owners that are best served with the aftermarket offerings. At that point... Selling your stock shocks will make some Std RMK owner very happy and you will be into the aftermarket shocks for much less as the sale of the stockers will take a huge bite out of the price.
In another post, you say that you have not tried a spring or valving change on the Pro RMK... but you know that you will not be satisfied with the results. Kind of self fulfilling way to look at it.
