Some Belt Drive Info...
Saw the 2013's yesterday in Fargo and talked to a polaris guy there because i had some questions on the belt drive. Dont know if this is somewhere else in the forum so i figured i would post it.
He told me that there will be no gearing changes. What comes on the PRO stays because of the lack of perfect pitch combos with the ratios. Also told me that the belts will not stretch but they will break in after a while of riding. He said that the belts should last about 2000 miles or so and they will need replacement. The cost of the belt wasnt finalized but he thought it would be somewhere around the same cost of the clutch belts.
Also talked to him about the carbon fiber overstructure and the 800 powerplant. Unfortunately, no changes in the 800 motor except for some ecu reprogramming. As for the overstructure, i asked about the strength of it if you were to hit a tree or similar front collision. He claimed that they have had no issues with it breaking. Told me it was lighter and stronger than the aluminum but had similar other properties. He basically said that you would have to roll your sled upside down hard on a rock or hit something to crush the pipe for it to cause damage.
Just wanted to share with everyone in case you didnt know yet. Thanks for reading!
The gearing for the 2013 Pro is the only ration that will be available next year. Other ratios will be available later. Cost of tooling and production inhibits gearing changes this year.
The belt will whine a little for the first 100 miles or so until it breaks in. Then it should be almost silent.
BELT-SNOW DRIVE, 36mm
This belt retails for $199.99 us
Should be changed every 2000 miles. That's crazy. A blower belt also whines all the time so I don't know how quiet this one will be.
What about this thread?
2013 Pro getting new cylinders and pistons!
I wonder which rumor about the 2013 motor is correct.:face-icon-small-con:face-icon-small-con
I would think that Polaris isn't exactly going to blab to anyone about have a problem with their motors.:face-icon-small-coo
"BELT-SNOW DRIVE, 36mm
Should be changed every 2000 miles. That's crazy. A blower belt also whines all the time so I don't know how quiet this one will be."
I think you are hearing the vanes in the blower whine.
"Not smart to put the brakes on the jackshaft instead of the driveshaft...
Just sayin.."
The brakes are on the jackshaft now I think.
I rode with a proto type 2013 after 1250 miles on it & there is a slight belt noise, but it isn't something I would worry about. Didn't notice it when I rode it, but I could hear it when not riding. Might own one next year. :face-icon-small-hap
i read gman's thread and i guess im not sure then. I just posted what the polaris rep at the show told me. Maybe they have new pistons maybe not. Although if they did, it seems odd to me that they wouldnt advertise it beings it has been sort of an issue with the 11's and 12's
As far as the brake being on the jackshaft, that hasnt changed in years. every chaincase model polaris the brake is in the same spot. you wouldnt have brakes with a broken chain and you wont have brakes with a broken belt.
If you break that belt you have more serious problems that the rotor being on the jackshaft.
