Item #1 Snowmobile Lift
I built this with some friends, and we made this one longer than the standard on the top rack for long track sleds, plus we added the raised arm on the back to support a sled more parallel to the ground; this arm has a pin that allows the arm to fold down while sliding the lift under the snowmobile. It also has the caster wheel kit, which is very useful for moving the sled around the garage / shop, and I also have drilled a socket (which bolted to the crank) that makes quick work of raising and lowering. All you need is a 3/8 drive on a drill. Would like to sell local unless you want to pay shipping charges (both items are heavy). Located North of twin cities MN. Would like to get $200 for it.
Item #2 I'll call this the rear end lift
Made this also. I haven't gotten around to painting this yet, so it needs to be cleaned with a wire wheel and painted with implement pain. I would like to get $150 for this.
$300 takes the pair together.
Text / Call Scott @ 651.442.0973
