Can you buy just the rubber piece that holds the snow flap to the bumper ?one of mine fell off somewhere when i had it off .Seeing the flap is an extra anyway the parts catalog doesn't show them .Let me know if someone knows about this
Rubber latch | 520002090 |
Can you post a picture of what you did? ThanksMy flap was getting sucked into the track on my 2021 turbo 165 the first time I rode with it, I used a large black tie rap to pull the 2 bumper straps closer together that moves the flap away from the track problem solved + easy fix and hasn't happened since. You can still remove when not needed, you can tell the difference with it removed in Deep Powder. Defiantly helps with cooling + reduces the snow chucks pelting riders behind you on the trail.
the two rubber "arms" from the flap that attach to the bumper need to be as close together as possible. this causes each arm to pull it's side of the snoflap out and away from the track. wrap a bungee or tie a line around the squeezed together arms to keep them that way.Can you post a picture of what you did? Thanks
I should have been more specific.So, no picture then? Hahaha you don’t understand Engrish!
. This might help
