Not sure how loose you ran your limiters before or how long your front arms are in relation to your shock length..... you're probably o.k. as long as the front shock does not suspend the skid when in the air. Over time you could put too much stress on the shock, alot of hanging weight on the shock...also make sure that the shock spring preload collar is at least snug against the spring when the sled is off the ground (lift the rear of the sled off the ground and check it) most likely will blow the collar apart if your limiters were partially compressing the spring with collar not snug enough, in other words it will be loose now......jmho
