SLP Stage 2 clutching
Visi
I know that SLP has their clutch kit with their pipe. I know that Carls also has a clutch kit. I am looking for what others have done and think. I don't care about running across the lake. I prefer on and off throttle and wide open clutching on the hill. Speed across the lake doesn't mean anything to me. Here are the specs that I have found on Stock, SLP, and Carls kits.
Stock Polaris
Primary Spring = 120-320
Weight = 10-64
Secondary Spring = 155-222
Helix = Straight 40
SLP Pipe Kit
Primary Spring = 140-340
Weight = 10-68 MTX adjustable weight kit
Helix = Straight 40
Carls Cycle
Weight = 10-66 stock or Belly busters
Helix = 64/42
I'm running the SLP clutching and it works very well for boondocking/hill climbing/powder busting. The only modification I have made is that I like the black/purple secondary spring better than the black stock spring for my riding style. I ride 8-10K elevation and find that the purple/black gives me much more consistent RPM at full throttle and is quicker to respond when getting in and out of the throttle. Other's prefer the stock black spring. Use a dehlrin washer between the cup and clutch housing with either.
Funny how we all like a little different feel! I felt the black/purple secondary spring felt lazy when I had that in. Luckily we have 2 SLP set up sleds in the group so riding back to back with the different springs was easy to feel.
Visi,
I have custom Tri-City clutching on my stage 3. Have not had a chance to ride it yet. Will let you know what I think of it.
Thanks man, I'm interested. Just put a SLP pipe on. Want to try a few things before I try kit clutching. I have a few springs I'd like to try with the stock 40 str helix and 62g weights.
In my opinion,any secondary spring other than stock feels lazy on bottom end, id like to try even a softer sec spring.
TTT
Any more updates/reviews on these or any other kits? Trying to decide weather to go stage 2 or just do the single with another kit.
i have found the SLP clutching to be horrible. Adding more weight and a stiffer spring is counter productive to me. if you add a pipe, more power will require more weight and a stiffer secondary spring to make sure the belt doesnt slip due to the extra power. I have found that the thin profile of the SLP kit to wear out the rollers very fast, and the weights are very heel heavy which makes them feel strong initially, but lack the top end shift out. Just go to 10-66 weights and add the SLP black/purple secondary spring. my 2 cents.
Clutching
I have tried other weights but ended up with the SLP weights and suggested spring in the primary. I also ran the stock spring in the secondary but I put the multi helix from the 15 pro in the secondary. The track hums when climbing.
Boom hit the nail on the head. Couldn't have said it better myself.
I think I'll try this. Thanks.
The Carl's helix has a dual ramp. I believe it can be a 40 at the bottom or a 42. I ran mine in the 42 ramp last year. Several of my friends had theirs in the 40. I am switching to the 40 this year. It is fairly easy to switch which ramp you want. The 40 ramp seems snappier and it pulls higher rpm under load. All three sleds have SLP pipes and 66 EPI Belly Busters. One of the guys runs a different secondary spring (not sure which one). He also ground his weights down to 65. He gets really high revs (8500+) with his setup. I am not sure that I want that. I like it in the 8300/8400 range. Everybody has their preferences.
935, what elevation were there sleds running at? Also, with the slp pipes, were you guys running the slp can or others?
Elevation is 5,000 to 9,000 on average. All three have SLP pipes. Mine has a Diamond S Titanium can which I ran early last year with the stock pipe.
