Almost every motor with a broken crank has an SLP pipe. SLP pipe loses low end and midrange power over stock. Don't waste your money, Just get a lighter Can and put on it. If you absolutely have to have a pipe get a dynoport.
OMG..this is no way near true..nice try zane..the PIPE has absolutely nothing to do with this happeneing, its 99.99% belt, motor mount issue...
i have SLP pipes on 2 05 900s, 1 06 900, 1 06 700, one of the best mods ive done, power is NOTICABLY better and never an issue with lean spots, rpms are 7900 and torque is unreal.
if you get a used pipe, i would jump all over it, i wouldnt buy new just cause the price is so $$...
and FYI, the 06 700 and the 06 900 use the SAME SLP pipe![]()
755 pipe is different part number than 900 pipe.
So, just to make it clear. The biggest reason I do not like SLP pipes on the 866 or 755 is that they are prone to failure and have a nearly 100% failure rate.
cracked cans
cracked y-pipe's
cracked brackets on the pipe themselves.
Even guidoxpress who loves them has experienced all or almost all of these problems with his SLP pipes.
