SLP pipe combo who has it?
srosscojw
Just wondering who is running the SLP Pie, Can and pcv on their Pro? Also like to know who has reeds as well.
How do you like the kit...
How well does it perform...
thanks in advance
I have the pipe reeds and PCV. Runs awesome ive had them on for two and half weeks. Runs much stronger than before. The throttle response is alot snappier pulls much harder all the way through the powerband. It even gets better fuel mileage than stock I wouldnt have noticed this but I ride with two other sleds identical to mine and I have more gas left at the end of the day now. I would highly reccomend the kit makes the pro run like you would expect it too.
I have pipe, can, reeds and pcv as well as a rk tek head on mine and runs flawless wouldn't change a thing. I think the power is more consistant now.
i'm running the dynoport pipe, stock can. Pulls harder, had to add +2 gr to mtx weights. Good mod No added fuel controler with the dynoport
I am pretty sure the slp cans were quiet along with the ultra q cans.
Their silencers are pretty quiet. You won't get stopped by the noise cops with their can. I have their single system on my 09 700 and like it.
It's so close to stock sound it's not worth talking about. The set up rips real good though.
^^^^ X2
I would also like to know if anyone that runs this pipe has experienced any bogging?
I would like to meet the PRO that doesn't or hasn't bogged. Irregardless of what is under the hood! I just hope the guy that owns it named Mr. Bigfoot will let me try it!
"Daddy what does mythological mean"
I looked it up on wikipedia and found it listed right under the term NO turbo lag.
:D:D:D
pipe bog
^^^^ X2
3500ft. pipe bogs realy bad untill its hot. you have to run around the flats to heat it up before any pulls. anyone else have this issue? this in addition to our regular cutting out and bogs.
i don't have a pipe, can, or pcV, just bone stock motor wise. 800ish miles and mine has never bogged. the only time i've got it to stumble was when i bounced it off the rev limiter. pipe related? i'm at sea level, elevation related?
pv
mine has never bogged once unless it was due to the huge amounts of snow covering the intake, that's the only bog my sled has had.
and as for the Pro in the vid it doesn't bog at all with the pipe set up, at least he hasn't mentioned it bogging but I never heard it bog in 8 hrs of riding last Saturday!
I RIDE WITH TREE BOSS ALL THE TIME THE ONLY BOG HIS SLED HAS IS THE RIDER:lol::D
