SLP pipe blowout!
Wheel House Motorsports
Curious how many miles you guys have on your SLP pipes setups.
I got about 600 out of mine and a section the size of my open hand started flapping open in the main bend in the front of the pipe with a bunch of cracks starting all around the support pedestal as well as around the EGT sensor plate.
Maybe its just my sled that is sucking but I seriously can never get this sled to pull the recommended clutching in those 600 miles either.
The newer setup has the 2 clamps. Mine still cracked and needed welding and it had the 2 clamps.
I think a strap with a strong exhaust spring might be better as it would maintain tension on the pipe. Hose clamps are a bit mickey mouse.
Jaws has been great on mine i have also had great luck with SLP.
Mountain Cat
1100 miles on mine, still great. Mine is an earlier version. Single strap, x weld
Sent from my SM-G930V using Tapatalk
Jaws pipe is good. So is slp or bikeman, I went jaws because they are built in canada and we're not having issues cracking.
