Ski, I am with you here!
"would rather running heavier weight and more spring, than drop weight from the arms".
I am trying the SLP Black/Pink spring. It's install and I'm just waiting for some fresh snow. The stock yellow/white is a 122/285 spring. The SLP Black/Pink is a 120/340 spring. If you tried such a spring, the engagement should be similar to what you have now but, you should pull a bunch more RPM up top.
On the helix issue, I'm glad you tried a 38 degree helix (Because I wanted to as well). I'm still suprised you couldn't pull it with ease. I wonder if it's the shim/deflection issue causing you grief?
Take care
Take care
