Sounds like a leak somewhere...
I have only had mine up to 14 lbs..... You must be running bigger injectors and more fuel delivery.. If everything is in proper adjustment and not leaking boost anywhere you should see your max boost right away.
I think if you over adjust the rod it will just raise the least amount of boost you can dial it down to.
