B
BeartoothDistributing
New member
Hey guys,
I am on here to let you all know about slidekicks ice scratchers,and to answer any questions or concerns about them.
Slidekicks is what I sell and my cousin is the manufacturer (between the lines designs) aka Trinty Taz.As such I have exclusive access to special pricing and I use the price breaks he passes on to me to the customers.I sell slidekicks on ebay as well as my website for 69.50 + free shipping anywhere in the U.S.Here is the links to both loctations that you can purchase them and get in depth info.
http://cgi.ebay.com/ebaymotors/Slid...wmobile_Parts_Accessories?hash=item4a9b8179e2
OR
http://www.icescratcher.com/
Here is some detailed information about slidekicks reverse compatible ice scratchers.
Slidekicks are a reverse compatible ice scratcher,that means no more bent or broken ice scratchers.
You dont have to worry about SLIDEKICKS breaking when you go into reverse after you forgot to put them up.
Or breaking them on the terrian and of course the all time classic bending them after you forgot to put them up before loading your sled on the trailer.
SLIDEKICKS are made of a cable that is not only indestructable and flexible but they also put great down pressure o n the snow and ice.
SLIDEKICKS have a different, yet effective technique in producing spray to cool your snowmobile. When not in motion, the scratchers stick straight out away from your snowmobile. The 45 degree mounting angle provides the downward pressure to keep the tip on the snow. When in motion, the SLIDEKICKS will be forced back toward your track & skid. The combined downward & backward forces cause the scratchers to constantly chip away at the snow and ice, creating a steady spray aimed at your hyfax and coolers
SLIDEKICKS also have replaceable wear points. So instead of replacing an entire set of scratchers, you can purchase our inexpensive wear points and replace them as needed. SLIDEKICKS are an investment that will save you money over the long term.
SLIDEKICKS are very easy to install and will work on any sled. They mount toward the front of your rear skid using one bolt. Many skids already have pre drilled mounting holes. If yours does not, you simply drill one hole where you want to mount your SLIDEKICKS. The tip is then bent back and hooked on the inside of your rails for it's resting position when not in use.
Last but not least slidekicks they are covered by a thirty-(30) day defective materials/workmanship warranty from date of purchase.
Thank you very much for your time and please feel free to contact me with any questions or concerns.
Here are the links to where I am selling them and my contact information.
Beartooth Distibuting
406-461-0361
OR
406-461-0361
