Slide Rail Cracks
M
maddogwfo
I bought a 2005 Kingcat the end of last season and I am in the process of adding a new Power Claw Track, anti stab kit, and ice scratchers when I noticed a crack:face-icon-small-fro on both rails near the front shock, any one had this issue and a fix, I have several ideas but wanted to run it by you guys, thanks for any input MADDOGWFO
Cheap easy fix drill a hole @ the bottom of the crack and throw some rail braces on.
Mine cracked also. Not in that same place but it must be those rails. I have mine welded.
That is common if you ride hard. The best fix is to upgrade your rails and front arm. I put the 07 rails and arm on as soon as they came out in 07 and have had them on since. The things needed are 07 162 rails, 07 m8 front arm, arm axle, rail inserts, 1/2" spacers that go between the tunnel and front arm, and wheel mounts if you are running your front wheels. I like the 07 rails also because the look stock on a king cat.
