For anyone looking for a great place to mount your GoPro camera, this is it! It's the perfect Point of Veiw! It's out in front and out of the way of your sight. While riding, you don't even know it's there. Mounting on top of the helmet seems like you have someone standing on a step ladder behind the rider or you'll see the front of your helmet visor. I don't like the side mount because you are losing one side of the POV and you still might have the helmet in the picture. To remedy these problems...
Remove the decorator plate from the front of your moto-cross helmet first. Fabricate a thin cardboard or posterboard demo that will work with the contours of your helmet and make sure you have a couple of tabs to bolt to the helmet whether they are top and bottom or on each side. Make sure that the dimension on the plate has enough room to stick the Go Pro hinge mount. Take your demo to your local sheet metal shop in town and have them bend one up for you. I brought my helmet in to their shop so they can see what the end result is fitting to. With the helmet sitting on a flat surface, make sure that the plate is tilted back a little not forward being that when you are on your sled, your head is tiled downward. Since I posted this subject I have altered the J camera mount that is in the first picture. With the camera housing mounted on the J mount, you can only tip the camera back until the housing hits the lower part of the J mount. I have removed a little of the plastic in that area on the J mount, and now I can get more terrain and sky from the picture than I did before. There is a front helmet mount kit from GoPro that has different pieces in it that will allow you to point that camera at a greater angle if you ride with your head pointing downward more so than others. Trust me! Enjoy some great POV movies!
