M
mynewuseddoo
I love the smell of AV gas in the morning......smells like...victory
good cheap ebay turbos... nice high quality parts right there..
working on the turbo. All the fittings are leaking. ill get you a vid you crack head...
Correct the turbo from the G-kit is a sweet little ebay unit.. I makes a ton of intake heat if you run more than 8lbs. I am no longer running it and went 4 injector.
Push wasn't using a chinese knockoff... I understood they were using the standard journal bearing Garrett on the G kits... Please confirm??
The Breeze. Actually Found your instructions from 2010. Helped a Ton.. Fired It up 5 minutes ago after rebuilding the regulator... and switching all 4 pins on box around. 100LL smells weird as hell
