Can I start it without the secondary on or will that cause damage?
Was the square key for the helix in the secondary in place so you could pretension the spring by 1/3 of a turn? The reason I ask is because I had one push out when I installed the helix and had basically the problems you are having.
I think that might be it. When I took it off the secondary, the round hollow bearing(?) and key just fell into the belly of the sled when I was removing it. BUT I did have to twist it and push down to get the helix to pop out to take the secondary apart. Does that mean it was pre wound or would that not matter?
What do you guys think about #11 part 2? (regarding running extra oil during break in)
http://www.smellofdeath.com/lloydy/piston_diag_guide.htm
1371G needles
38 pilots
182 jets
ACCS is removed, carbs vented into airbox
I'm at 6-9k
It doesn't appear to me that the belt is sucking down into the secondary. Should it be really noticeable that it is going down in there?
The primary is engaging and staying closed.
I put the spring the #2 position in the secondary and spun it before installing.
I'm giving it WOT and just not getting the kick and topping out at 4500 rpm's. Can you download video onto here? If so I'll take one with my phone and show you guys!
