sled really rich at idle
I have the same problem right now, warms up light goes out and stalls running rich. Was going to change the temp sendor as well but you say that didn't work?
did not work for me but may work for you as a bad temp sensor will cause this,iam still trying to find my prob
I wonder if your idle problem is caused by the Idle Speed Controller (ISC) most will stuck open causing a high idle but I wonder if they could stick closed as well. In the shop manual it says you can't change them but I have one apart now that was stuck open and waiting for a replacement.
Also if you look online at the microfiches the only year that gives you a part number is 2008, all other years will come with the throttle body only.
