Sled damage?
kylant
sled center punched a tree yesterday. hit pretty good. destroyed an aftermarket bumper. looks like the bumper sustained most, if not all of the damage. i will take a close look at it today. are there any areas to inspect that are easily overlooked? i am most concerned with the bulkead.
thanks
Usually only the pipe gets dented/crushed. This is why a better bumper is a good idea. Pipes are expensive. Also look at your tunnel as if you hit really hard I hear it can buckle where it meets the the bulkhead.
Get an app on your phone to take date and time stamped photos as you go. One for reference but mostly if you find something big and need to turn it in to insurance it is easier to prove the damage to an adjuster/ damage appraiser for the insurance co. I used to be one, pain sometimes when you get a claim, sleds in pieces, have no idea what condition the sled looked like over all before tear down if you have to pull a valuation to assess for a total loss. Get photos of the ODOmeter reading, VIN#, all 4 sides, damage area etc like a sales add and then photo the damage as you come across it. If you have all that it will make the process go much faster and easier to settle.
That said, I had a lot of shops that missed stuff on their estimate until I inspected. Everybody wants to focus on just the area of the impact or the obvious damage without checked ski alignment with the track etc, looking for signs of something twisted and then have them tear into it and follow the path of the crash inertia directing the crash energy. Example, impact on the front right, follow the direction all the way through the vehicle as if whatever hit it came out the opposite side. On yours, You center punched something so the crash energy goes all the way straight out the back. Don't look at just the impact area. I'd be looking at ski- alignment, any twist in the tunnel or differences in gap between the mounting to show signs of stress or possibility of something tweaked, seat alignment and how it sits on the tunnel, fits with the tank and plastic, clutch alignment helps look for a busted motor mount, twisted driver or jackshaft, bulkhead etc. How's it run? cooling ok? Any of that stuff seem odd I would probably stop and call insurance since a bulkhead, tunnel etc gets expensive quickly and you want to point that out to an appraiser and have them give the authority for teardown (Save you the time to do it and just have a shop do it and let your insurance pay the tab). I had a few guys that were happy as he L L that I looked at it, and decide, no, tunnel, bulkhead etc, total out the unit without doing a complete teardown. Pay them the settlement, they kept the salvage, pay off their loan and/or buy the parts they needed to fix it or put towards some kick azz aftermarket stuff to upgrade to and did all the labor themselves. I had alot of authority to make that call with my company an higher ups didn't know squat about sleds and they just saw that we didn't get in over our heads on sleds anymore for repairs and everybody was happy.
Dead center usually isn't bad just expensive. The pipe/plastic bumper / hood all crush and slow it down. Not cheap if you wreck them all but the diagonal hits right at thr base of the a arms are more likely to do major structural damage.
As mentioned. Thaw sled out ans give it all a big once over. Also check underside of hood glove box airbox etc. I see a lot where it splits seems apart in airbox and guys don't replace them and you end up having weird snow ingestion issues.
thanks all. so far i am not seeing any damage other than the bumper. the bulkhead looks good. no cracks or other issues i can see back to the tunnel. will go look at tunnel now. the skis and suspension did not hit the tree. they straddled it. the sled hit square in the middle of the bumper. the tree was maybe 12" diameter.
Advice, use the beer can rule. If it's thicker than a beer can, don't try to run over it or through it.
lol. i was about to get stuck on a steep pitch. so i turned out and slipped off the running board. sled got a way from me. 15 feet later, smack ??
the hit was so square that it is not dented on one side or the other. all the damage was at the bottom where it mounts to the bulkhead. the bumper was pushed down and folded
so after spending a great deal of time looking over the entire sled, i didn't find any other damage. no bulkhead cracks, tunnel kinks/wrinkles, motor mounts intact, etc...
i think the bumper took all the damage and did it's job.
all the nosecone, side panels, and hood plastics returned to their fabricated state after being in the sun. new bumper installed and everything looks back to normal.
thanks all ??
DAF5BEA4-D698-41F5-8CC6-274E225D383D.jpeg E5208BB2-7E18-460B-8C89-421A5D623025.jpeg
