I have a 2018 SKS 155 with a 2.6 lug. Sled handles and accelerates well ,but doesn't hardly lift skis. I softened the rear track shock a bit and also ski springs. That did nothing so I put it back to stock. Now I put more spring pressure (shortened spring) on the front track spring, but the owner's manual says you can only move it .175 inches from min to max. Is that correct? (On page 69 of manual.) If so that means there is almost zero adjustability. I would like a little advice on what I need to do to lift skis more on acceleration. They don't need to be 4 feet in the air, but a foot or 2 would be great. I am about 210 pounds with gear. According to suspension set up in manual the factory settings sbould be pretty much spot on for my weight. Thanks in advance.
