SKS A-Arms
IFlyEm
Polaris Klim 509 BCA
I have a 2020 SKS and have been reading about the designed weakness in the lower A arms. I am going on a 5 day trip and want to have a backup set.
A couple things:
1. Are the SKS A arms identical to the Pro RMK? I can't find any SKS specific A Arms
2. I see the 2017-2019 shared the same part number but it changed in 2020. Did Polaris make the 2020 A Arms more robust?
Thanks!!
They're still weak. Buy a set of after market a-arms and sell your stockers to off set the cost.
Sent from my SM-G965U using Tapatalk
Which aftermarkets would be the same geometry? I can only find RMK and Switchback.
Thanks!
Its the same as a rmk non react front end. You can run k-mods which are 37" a-rms and use your stock shocks but you have the ability to go to a 36" stance (react width) or out to stock 38". Zbroz and alt impact also have the standard 38" a-arms available.
this ^^^
the SKS still uses the NON-React front end.
So they are the same as the Pro non-react
I did the Trenchers this year. Takes you to 36" and you can reuse your factory shocks. They seem to be pretty good quality.
