Skinz Airframe Side Panels
kyler25
Just curious if anyone has ran a set of skinz air frame side panels on their pro. Just want to know how well they hold up and if they're worth the money. They seem to be very proud of them for what they want retail for them. My biggest concerns is how the mesh holds up. Let me know if you or your buddies have ran these and how they like them. Thanks
I have a pair on my silber turbo'd sled and it burnt a hole on the inner mesh not the outer but that was due to the turbo pipe they look nice
all in all there a nice product but still not sure if there worth the money unless you were gonna buy different colored side panels anyways like I was going to
Same here. Bought the sled with them on it. Turbo burned a the inside mesh when side hilling but not the outer. There mesh holds up very well. Also you can buy just the mesh parts to replace if you ever need to. As far as fit and finish they are top notch.
stock sled
So do you think if you had your stock sled on its side would the can burn a hole in it as well?
It would probably melt as well would be my guess. Its only the inner layer tho not the outer. You cant tell unless you pop the panel off. And it only melts a spot the size of a 50 cent piece
Here is a picture of the skinz side panel. you can see in the lower left portion of the panel is where it contacts the turbo.
[/IMG]
I have been looking for a set of these but no luck finding any! where have you found a place to purchase them? thanks
