Im trying to remove my skid (2012 SBA) and im stuck
I've got the track loose
I've got one bolt out of the front (right side) and one out of the back (left side) once i go to the other side and try to take the others out it just spins in both cases impact or by hand....note i did spin the other side first by hand and not impact
I see theres a bearing in there to keep the bolts from backing out when riding...
I end up putting a 2/12" bolt with a nut and washer in there run it all the way in while holding the other side and snug it in good... then back it out a half turn and lock the nut good and tight against the tunnel
goto the other side and start to loosen the other bolt while holding the one thats locked against the tunnel it never pulls out and just starts loosening my bolt thats locked against the tunnel... im using hand tools and tried a makita 18v impact with no success
Ive also tried it with running the bolt all the way in tight and then locking the nut on the tunnel and then trying to loosen from there and i get the same results.
I havn't tried this trick with the back where i'm having the same issue but...
what am i missing here?
